Old Pex Tubing
Ron Schroeder_3
Member Posts: 254
how old the tubing is. Barrier tubing has not always been.
I am working
in an old log cabin where the previous homeowner installed a radiant floor all on his own with the help of an internet company selling him all of the materials. Eep! It is run with what looks like 3/4 pex tubing. They have already had to replace the cast iron boiler before I was contacted because of a motorised 3 way valve bring back cool water with no protection. My concern right now is whether the tubing is Oxygen barrier tubing or not. The only printing I can find on the tubing says, "Solar Option One Co. Heat Exchanger Tubing." Does anyone have any idea what this tubing is and does it have oxygen barrier protection?? Thanks for any help. WW
O2 barrier or not
Hi Wayne. An old fox such as yourself will know what to do with this stuff whether it is barrier tubing or not. My old mentor constantly reminds me that the tubing only accounts for approximately 30% of the total O2 that diffuses into a heating system. Where does the other 70% come from? The )2 barrier is highly overrated and lulls us into a false sense of confidence to the point where we no longer consider the chemistry of our heating systems.
I have many old and new heating systems built without barrier tubing. I do pay attention to keep my fluid temperatures as cool as I possibly can though. Cooler fluid takes up less O2 through the tube wall.
If the customer wants a heat exchanger to protect their new boiler, please give them one. If the boiler manufacturer requires one to maintain warranty, insist on it.
Consider either a fourway motorized valve (the Vitoronic 300 controller is on special) with a high temperature boiler, or a threeway valve with a stainless steel condensing boiler.
The 3/4" tubing will carry a lot of BTUs for you.
Also, remember corrosion inhibitor please.
You know what to do.
Shalom0 -
Look for EVOH layer
Should be a "peelable" clear layer discernable on the surface of the tube. Be willing to bet that it is not barrier! Most tube sold over the 'net has typically been plumbing pex, not heat pex.0 -
So, where does the other 70% come from?
I'm curious aswell
where's the other 70% come from. Did you use HX on these older installs?0 -
Crap tubing
Thats what Bob at RadiantTech used to call his tubing. It's basically a non listed poly ethylene tubing and you're correct, it has NO o2 barrier.
Same old same old...
ME0 -
Job is about
15 years old I'm guessing. The original Homeowner is gone. Should I treat with chemicals or install a flat plate or both??? WW
I'd isolate
the tube with a HX of some sort.
A small indirect tank, 20 or 30 gallon, makes a nice HX sometimes, and offers some buffer capacity, which can help a lot on micro zoned non modulating boilers.
I would consult with the owner regarding any warranty or expected life of that tube. Before you start!
hot rod
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
