Riello F15 into Peerless SCT???
Gman_3
Member Posts: 27
I'm a end-user customer who'd I'd like to put a Riello F15 into a Peerless SC-06. There are no specs in the literature that the Riello is supported. I called up Peerless, and they confirm that they haven't tested it either so it's not supported.
One prospective installer states that he won't put it in and says because it's not supported, it won't be UL protected, etc.
Any feedback would be appreciated. Thanks. gman
True
If the installer put one in with out the manufactors blessings or makes changes to their instructions ,he is taking all the responability of any mishap...0 -
I would do it if
The chamber meets the Riello specs for that burner and all of the safety controls are working as they should.
David0 -
Riello in SC
gman, where are you located??0 -
Westchester County, NY.
Are you now working for Riello (after Carlin)?0 -
Yes and no!!
I work for the New England rep for Peerless and Riello. Send me your telephone # via e-mail and I'll give you a call.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
