reverse return
j a_2
j a_2 Member Posts: 1,804
installing 3 kickers with one 2 ft c/i baseboard it was suggested using reverse return piping ,sounds good to me but open to any other suggestions....should i use monoflow tees.....thanks for you usual professional suggestions ja
  • jeff_51
    jeff_51 Member Posts: 545
    I think most guys on this site
    would use reverse return. I would. I have used mono as I'm sure many here have, but only when other considerations made reverse return impractiacle. I know, I can't spell
  • Al Letellier
    Al Letellier Member Posts: 781
    reverse return
    the flow rate through toe kicks and CI BB is entirely different. Properly sized, reverse return would work, but mono tees is a lot easier for most guys to understand and install. Not knowing the layout and heat demands of your job, I would lean to mono tee loop.
