just another house on the water
Weezbo
Weezbo Member Posts: 6,231
  • R. Swatton
    R. Swatton Member Posts: 86
    Doing a radiant install.
    Basement in slab, first floor plates, second floor hydro air. Using 2 199 Munchkins,2 119 Super Stores,flat plate heat exchanger for pool. Tekmar tN4 controlls. House about 15,000 sq ft. Maybe adding indoor tenis court.
    Work is in progress. Installed basement pex and insulation in main area, waiting for pool to be installed before doing the other half.
    Rich Swatton
    Summit Plumbing and Heating
    Authorized Heat Tranfer Products Sevice Agent
  • lchmb
    lchmb Member Posts: 2,997
    little
    Just a little house! Look's like that will keep you busy for awhile...Make sure to keep us updated as it goes..:)
  • hr
    hr Member Posts: 6,106
    I can't see the forest through all the
    posts! What's up with all the posts under the I beam? :)
    Have you considered two 50 gallon indirects instead of the 119. I priced a 119 yesterday and discovered I could install 2- 50 gallon tanks and save over $600!
    Looks like you are embarking on a fun project. Keep the pics coming.
    hot rod
  • R. Swatton
    50 gallon tanks
    My loyalty is to HTP so its 119 gallon tanks. The specs also call for Super Store.
    I am not doing the plumbing, and yes all the drops are no hub for sound.
    Will keep you posted with updates.
    Installation of plates next phase. Trying to staple the plates up instead of screws.
    I am having a problem with bay widths. Every other bay is 12" and next is 7 ". Thinking of cutting the plates to make them fit.
    Rich Swatton
  • S Milne
    S Milne Member Posts: 112
    Rich
    Nice Job wish I got it :)
    That company your so loyal to makes a great 60 gallon tank and two of those would be ....
    Scott
  • radiant_2
    radiant_2 Member Posts: 6
    WHy in such a nice home would you be installing the radiant under the joists bays???????????
  • jerry scharf_3
    jerry scharf_3 Member Posts: 419
    Tfin?
    Rich,
    The radiant engineering thermofin comes in single runs 4" wide, so you wouldn't need to cut those. Stapling up plates is indeed the way to go, fast and strong. I really like Dale's products.
    jerry
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Good Question....
    Since the framing is beefed up, why not an overpour?? The cost of a stapleup with irregular joist bays is excessive and very labor intensive. Sometimes it's most difficult to control the design and application with the architect, builder and homeowner involved. These are larger industry-wide issues that influence the system design. Sometimes the floor coverings and finished floor heights are issues. I've often swayed the argument against overpour with the soundproofing and fireproofing advantages of the lightweight overpour, and reduced operating costs of running the system at lower water temps. Often the architect (or homeowner) is determined to using conventional hardwoods, instead of laminates or pre-engineered products. You have to know where and when to choose the "battles".
  • R. Swatton
    Super Stores
    I am installing 2- 119 Super Stores 238 gallons then we are going to mix it down.Installing a couple of car washes for showers.
    The over pour issue was not considered when the house was designed. Radiant wasn't an option then either. That's why we are using staple up. Really not my choice. Rather use quick trak. But you have to remember every job has a budget..
    Rich Swatton
