Diagrams
ralman
Member Posts: 231
diagram of my one pipe monoflo distribution system to attach to my posts so I can get some input on some design issues. Thanks in advance.
Draw it on a napkin and take a picture.. Just kidding. But it would work! If I were you I would try and do something in your computers paint program.0 -
If it is something related to our previous posts, Ross
the napkin thing is hard to beat!
Graph paper or plain white paper is fine. You can scan it or fax it to me off-line if you like (that is, if it is related to my offer of help).
Brad0 -
Taco.com has a free download program
It may be of assistance to you to convey your current set up.0 -
Yes, it is directly related.
This will take a little time due to trial and error. I don't use the computer for scanning, faxing and drawing so there will be a learning curve for me first. I have to go to work soon... I will try to draw and send it to you ASAP. Tomorrow at the earliest. Thanks.0 -
Excellent, Mike!
I forgot about that. It is based on "HVAC Solution" and is a limited distribution version founded on Taco's "Load Match" program. I have the HVAC Solution Pro version so this is just a part of that. Still it is a unique and robust program that also does some calculating.
Good call, Mike.
And Ross? Your spare time is now GONE!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
