Big bang theory
Holycack
Holycack Member Posts: 12
Ever since being installed 2 years ago my V84 Burnham boiler with a Beckett burner has started with a loud bang then boiler runs normal. It sound as though it has an excessive amount of fuel in the chamber and ignites with a loud bang. Anyone know why? Thanks in advance for all the help.
  • bigugh_4
    bigugh_4 Member Posts: 405
    big bang ?
    do your self a favor and look at "fina a pro" on the left and spend the $$$ to have your bangs cut. Hard ignition is no place to start fooling around trying DIY. Ya could loose your eye brows!
  • lchmb
    lchmb Member Posts: 2,997
    was it
    Was the boiler set up properly to start? Has it been serviced since the install? If so did the tech inidicate any issues?
  • John@Reliable_10
    John@Reliable_10 Member Posts: 99
    What did the new boiler replace?
    If you replaced a old 1725 burner w/new 3450 w/ delay valves, post/pre purge it will sound very diffrent.I have installed many Burnhams and found that some were loud on start up no matter what we did.(Yes we use all the proper spec's and Pro125 tester)but just couldn't get a good lite off. We would solve it by installing a diffrent burner,a Carlin EZPro. These for some reason will be about 75% better in the loud dept on lite off and during the run cycle,even with-out a noise cover.
  • clammy
    clammy Member Posts: 3,212
    call a pro
    Call your oil service company and have a service dude come on out sounds to me like someone may not have set it up ,i have worked on alot of becketts and have always been able to get them to running sweet ,Delayed igition only has a few causes like electrodes to advanced ,no oil delay ,high vacune,oil pump losing it prime,wrong z deminesion or maybe pump pressure and wrong noz .Call a pro it can be corrected .have check your vacune also ,them install a pre post purge relay with a oil delay valve ,peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Weezbo
    Weezbo Member Posts: 6,231
    Bang! is Not Good. Trust me on this one *~/:)
    bust out the combustion test kit:) or spot a service tech a few dollars for gas and groceries. :) BTW BOOM! is not Good Either :)
