Cleaning Baseboard Radiators
G Lyons
G Lyons Member Posts: 36
from the top and a vacuum cleaner from the underside, Moving them along together... makeing sure none of the lint etc goes into the room.
George
  • JD_7
    JD_7 Member Posts: 5
    Alot o' talk about Baseboard heat! I like it. Do you ever have to clean a baseboard radiant system out? If so how?
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Shop Vac
    and a long bristled gentle brush. If stuff is really stuck in there (like you have a dog or a cat or a few of each), set the Vac on "blow", wear a respirator and hope for the best.
  • joe_66
    joe_66 Member Posts: 30
    make sure to clean the bottom of the fins sometimes they look clean on top
