Is pex used with baseray cast iron baseboard?
ralman
Member Posts: 231
If so, which type?
I thought I had read a long time ago that there is a temperature limit for the water that is circulated through pex.
Would it be a good idea to scrap the existing large diameter and lengthy monoflo iron piping scheme in favor of zoning with pex?
If so, which type?
Lee, a local master plumber i know is spinning in some
individual runs to some existing Gravity system that he has dialed in thru a Viessmann. i will try to get a picture or two today for you. it would depend upon your expectations to some extent. with all the new insulation and losing the entire system basically in favour of a more "Modern" system and a few myson panels in the future i expect it will preform wonders on fuel useage and hot water production in the B&B.
The carpenters hacked all kinds of the system up and almost yanked the expansion tank out Ya got to keep an eye on them
i voted for keeping the entire system in tact and letting the customers 'feel the real'
of the past with the added set point controls out door reset and those sort of energy saving devises:) keeping it Up to speed
it is going to be sort of a museum some of it functional some of the thing just Being.0
