All wall mount
  • Henry_5
    Henry_5 Member Posts: 17
    Trying to get a handle on all
    the wall mount boiler systems available. I just went to ASHRAE, nice job Chicago, and saw several. By my count:
    Triangle : Prestige
    HTP : Muncher
    Buderus : GB 142
    Quietside : Quietside
    Embassy : Ambassador
    WM : Ultra
    NYT : Trinity
    Vi : Vitodens
    Lochinvar : Knight
    Pinnacle : Pinnacle munchkin(?)
    Baxi
    That is where I stop, what else is available.
    Thanks,
    Henry
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Monitor: MZ (also only condensing oil model available in the US but am unsure of model designation)
  • hr
    hr Member Posts: 6,106
    Not all of those are actually wall mount
    but are modulating condensor boilers. Add the Crown, SlantFin Bobcat, Laars Mascot.
    hot rod
  • Greig
    Greig Member Posts: 5
    We use Baxi's in Alaska and they work great no problems (very few) also with the Roca made by Baxi you can set the firing rate to a low fire wich is great for small jobs where the heat loss is small.
  • Henry_5
    thanks Hotrod
    What's the skinny on the Bobcat and the Mascot, I have not heard of either of them.
    Henry
  • Nron_13
    Nron_13 Member Posts: 164
    IBC canadian boiler
    Wall hung boiler VFC 15-150 mod con boiler
  • Brad White_30
    Brad White_30 Member Posts: 26
    Monitor FCX
    Do not know if it is made by Geminox ("Made in France"; I hear that Conehead line from Saturday Night Live when I think that..)
    I don't think the FCX is wall hung though. I could be wrong. It does vent directly outside though.
  • Cando
    Cando Member Posts: 1
    Laars Mascot
    The laars Mascot is a Baxi 330 brand named for Laars through Bradford White
  • hr
    Henry
    The Laars Mascot looks a lot like the Baxi to me, possibly similar components.
    The SlantFin Bobcat looks to be the only condensor built from the ground up. They designed their own aluminum heat exchanger. A nice looking boiler with colorful jacketing.
    Haven't seen any lit on it yet, but it was at prowling the the AHR show.
    hot rod
  • Dennis
    Dennis Member Posts: 124
    I think
    the monitor is also made for gas?
    I think I saw one with an add on heat exchanger for potable water.
  • Constantin
    Constantin Member Posts: 3,796
    Floormount AFAIK...
    Geminox makes the FCX chassis, the burner is made by Heatwise in LI. Didn't seem that massive though, I'm sure you could mount it on a stand if you really felt like it. However, given that I seem to remember servicable parts (like the HXs) being accessible from the top, raising it too high would be problematic.
  • Brad White_30
    The Monitor MZ
    is their "bread and butter" line (the 25C, 25S and 40C). The 25S has an instantaneous hot water heater.
