water heaters heating house
hr
Member Posts: 6,106
built by Bradford White. It is a enamaled steel tank with a 1-1/2" steel coil inside for the heating. Several sizwe and an oil fired version.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
water heaters heating home
does any one have any input on using a 50 gallon bock oil hot water heater to provide domestic hot water and a small hydro air system. any good practices with this type of system. thanks in advance for any input0 -
You might want to separate your domestic hot water from any space heating loop. I have heard that in the non-heating season water in your heating loop may develop bacteria because it is stagnant rather than actively circulating as it does during heating season. This may cause contamination of your domestic hot water supply.
I disconnected my fhw loop off the the domestic hot water heater last spring and tied it into my steam boiler.0 -
Local codes permitting, water heaters are sometimes used as boilers, but proper safety devices must be added. As suggested such is [usually] only done for small loads.
Not a good idea to combine domestic water heating and space heating in the same device. As mentioned, truly nasty bugs like Legionella are a serious concern and will thrive in the hydro-air coil during the non-heating season.0 -
Consider the Combi 2
built by Bradford White. It is a enamaled steel tank with a 1-1/2" steel coil inside for the heating. Several sizes and an oil fired version available
hot rod.
Absolutely true.
In addition, I have worked with Bocks in systems before. I am not impressed with the efficiency and the suckers are LOUD.0 -
I have a bock
No regrets on the purchase. Just wish I had put in a draft damper to stop the heat from rising out my chimbley.LOL(slang for flue pipe)I could still add one.. I would just have to push the triple wall a bit further out the roof.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
