Steam main venting
Chris Jones_3
Member Posts: 12
I have been reading the wall for several years, just bought a house in S. Vermont with steam heat. I have a one pipe steam system with two mains each approx 45 feet long, 2.5 inch o.d. pipe. They currently have Dole #4 main vents at the end of the mains. One of these main vents is not venting, the other works. What size vent do I replace the non-working vent with? Is the #4 appropriate for the size main? My other question involves venting radiators, in rooms that overheat I have adjusted the Dole adjustable vents to lower venting settings and this is causing some whistling. Is this normal?
Thanks Chris
Thanks Chris
Steam Main Venting
Thanks Chris0 -
Both your mains
should be vented with a Gorton #2. This is a much bigger vent than the Dole #4, which is positively Lilliputian.
Your overheating rooms are the ones closer to the boiler, right? Once the Gortons are installed, you shouldn't have this problem.
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
