oil fired boiler
calling a Pro! Try the Find a Professional page of this site.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Matt_44
    Matt_44 Member Posts: 1
    Burnham Oil boiler trouble
    I have a burnham boiler, my problem is it will not fire does any one have any sugegestions? I replaced the flame detector sensor.
  • Steve_35
    Steve_35 Member Posts: 546
    There are simply too many possibilites to list.
    And you didn't give enough information to even start heading in the right direction.
    For example, you said "it will not fire". Does that mean the burner motor doesn't even try to turn over? It turns over but doesn't light off. Or it lights off but then quits right away.
  • Weezbo
    Weezbo Member Posts: 6,232
    i have a few...
    get a clean bucket and put some clean #1 oil in it..drop the supply and return into the bucket.. once the boiler fires leave it allone.....once the temp reaches 100F turn the power switch off.
    wait 10 mins watch the temp pressure gage. it will automatically rise about 10 more degrees..
    then turn the power back on and run the boiler until it reaches 140...turn it back off...wait 10 mins...the pressure and temp should both change a bit...
    turn it back on again...leave it alone then go turn up a t stat and listen for the circ pump to run....
    you got heat...
    if not,
    put the by pass plug in the return and try again...
    if it doesnt fire and keep going you have eliminated the power and fuel variables from jump street...call a pro if it dont go...
