Recommendation for remote T-stat
Constantin
Constantin Member Posts: 3,796
Honeywell or Totaline that are wireless. Might be worth a consideration.
Another option are Tekmar T-stats with multiple sensor inputs. Depends on whether you can run wire to the new location, I suppose.
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    I have a Thermostat that was placed next to an exterior door. Wrong. Now that the walls are all complete, I need to install one in the proper location.
    This is a community facility, so I would like to have a remote sensor that can be located anywhere and then locate the control in the boiler room. That way no one will tamper with it. I also need night set-back and cooling.
    Can anyone recommend a suitable device?
    Steve from Denver, CO
  • Marty
    Marty Member Posts: 109
    2 possibilities
    Robertshaw 97 0r 9800 series would be worth a look, or The T7300 (I think) from honewell. Both Have remote sensing options or ways to lock or restrict settings people can change. Sometimes restricting settings is a better option than a remote sensor. Unless there is someone on site all the time for seasonal changes and minoe adjustments.
