vaporstat question
john_27
Member Posts: 195
Thanks to a member of the Wall, I have a vaporstat on my broomell.....the sttings are 3.5 for the right gauge and 2.5 for the differential...with this configuration...I high fire for 4-6 minutes and go to low fire after that....2 problems:first....I get swing back and forth between high fire and low ....ie.cycling on a 40 second interval. Second...when I am clearly in low fire....the system tries to reognite to high fire....even if the mercury is clearly to the left....I've tried different settings on the differential...what's happening here?
- 120 Geothermal
- 394 Solar
