can't find a target wall
Eric K
Eric K Member Posts: 3
I have a customer with an enerjet boiler. the target wall is shot. enerjet out of buisiness. local suppliers do not carry parts. WET PACK??????
  • Ed N.Y.C.
    Ed N.Y.C. Member Posts: 73
    Target Wall
    EJK, Get a roll of kaowool , the good stuff made by Lynn and a can of spray tack. Remove old wall and wire brush it nas clean as you can, when you think its clean do it again. Cut the Kaowool to size, I use a pair of really big sizzors,spray the back wall with the spray tack and carfully install the wool,make sure all of the wool sticks to the wall ,the corners should get special attention. Let it sit for about 1/2 hour,recheck you work install front plate and fire it up. Hope this helps ED
  • Leo
    Leo Member Posts: 770
    I have
    I have used a Quickie chamber and cut it in half using one half as my target wall and discarding the other half.
    Leo
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Hi Leo
    Save the other half for the next one ;-)
    David
  • Leo
    Hey dave
    Hopefully if it takes this type of refit there won't be a next one.
    Leo :)
