Leaking Ultra plugs!
Tom Elam
Member Posts: 57
Do a search for "WM Ultra heat exchanger plugs" . I went through the same thing this spring. There was a man at a Ferguson store that offered to help me. He has what you need.
Tom Elam
Tom Elam
Leaking Ultra 155 plugs!
Anyone have advice? W/M says distributor should give replacement kit free, distributor says part # not even in system, useless local rep co doesn't even answer phone. Are they hard to get out? Any tips?0 -
Which plugs,
are you talking about on your 155 Adam?0 -
Sorry.......
Sorry, the plugs on the cast aluminum block. The initial problem was corrected by W/M but many older models need to have the leaking plugs changed. It looks like they'll back out with a large sized Alan Wrench?0 -
think laqrge flame
i need to use 2 large tip torches and get to block glowing, w/m uses some type of lock tite. My local rep wanted the hole boiler back, said i would strip the block first.0 -
ULTRA 155
Do a search for "Ultra 155" . I went through the same thing this spring. There was a man at a Ferguson store that offered to help me. He has what you need.
Tom Elam0 -
W/M Ultra...
Adam,
Where are you located...W/M is now using freeze plugs in their cast aluminium block so the leaking plug issue is no longer an issue...As for the local rep I would love to know who that is or at least which local you are in...I might be able to help with the no response...I also can get you a free plug kit if you need...let me know...0 -
Changing the plugs...
isn't a big job... I think they even send the alan wrench you need with the kit...just shut off the water to the boiler, drain the boiler, and replace the plug. The couple that I have done were no problme and the whole job took maybe 1/2 hour.
You had one offer for help here, you also can call WM's tech. line and my experience has been very positive with them, they will get you help...
Floyd0 -
Rep
Unresponsive rep is:
METRO
619 River Drive Center 1
Elmwood Park, NJ 07407
TEL: 201/797-8550
Either no one picks up, or voicemail is ignored, really sad.0 -
Maybe he has so many complaints he hasn't had time to get back to you.0 -
Right from the website....
Consumer Inquiries
Weil-McLain products are serviced through professional heating contractors. If you are experiencing a problem with your boiler, the first step you must take is to contact your installer or a heating contractor of your choice.
Weil-McLain Consumer Relations department hours are from 8:00 a.m. to 4:00 p.m. Central time, Monday through Friday, excluding holidays.
Phone: 219-879-6561 ask for Consumer Relations
Heating Professionals Pricing? Contact your local distributor.
Technical Services:
Phone: 219-879-6561 ask for Technical Services
Adam,
I'm quite sure that in you call this number that you will get a response.... they surely will get someone on the horn for you....Why are you not calling tech. services??? I think that, that is what they are there for....you got problems, they got or get anwsers.....
Floyd0 -
PLUG KIT
Drop me a line with your info. I have a repair kit in my office.0 -
Block Plugs
The few I've changed out were UPSed to me quickly by the area rep. Try e-mail to tech support. They seem to respond quicker via e-mail than phone. I'm sure they'll ship from the factory.
The old plugs came out pretty easy but be careful not to crossthread the new ones. Work the replacements in and out like you are tapping threads if there is resistance. Kerosene or fuel oil is a good lube.
Good luck0 -
Adam
The rep we use is in Mt Laurel NJ. I have no problems getting a hold of him when I need to. Weil-Mclain 17000 Commerce Parkway-Suite B, Mt Laurel NJ 08054 856-866-7400, 484-651-99000
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
