Tekmar 150 Settings
MikeL_2
Member Posts: 522
I have a 3 zone in-slab area and a 2 zone staple-up with pans area both controlled with separate tekmar 150 set point units. Can anyone suggest settings for the differential and cycle time variables?
I have a 200K BTU NTI boiler with a tekmar 356 control and outdoor resets.
I have been running with differential setting of 4F and a cycle time mode of 4 minutes in Pulse mode. I looking for help fine tuning these settings.
Dan.
Dan.
why mix?
if i'm not mistaken, the nti has a (primitive) onboard ODR control, using a 356 mixing control kind of defeats the purpose of a condensing boiler, you want the lowest return temps you can get to maximize the boilers efficiency.
i would set the curve of the boiler to meet the demand of your highest temp zone (staple up) and use the 356 to mix down for the in-slab.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
