CI rad enclosure question
Timco
Member Posts: 3,040
I looked at a large (36" h, 36" long) CI rad that is sitting in a recessed box. Surrounded by sheet metal, and built in real tight. What is the proper opening area around the rad for proper convection? The room is being remodeled and this is my chance to have the recess opened up if needed. Rad is sized for the room, but does not convect well in the recess.
Tim
Tim
> Tim
2½" is the magic number.0 -
page 80
of the hoffman data book should answer your question http://www.heatinghelp.com/pdfs/310.pdf
Would a larger area across the top (taller) help dump heat into the room? Slanted out? A new cover is being made as well...opening / grille design ideas?
TimJust a guy running some pipes.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
