indirects
ALH_4
Member Posts: 1,790
One thing I like about the coil-type tanks is that the hotter boiler fluid is encased in the water it is heating. This reduces heat loss off the tank when compared to a tank-in-tank version. I also would not use a fin-tube heat exchanger in a water heater for the reason hot rod mentioned. I also agree that it is a good idea to look for a tank with a good access hole for cleaning. As a side note, the Crown/Burnham stainless 120g tanks have more surface area on the coil than a Vitocell V 300.
Favorite indirect
Just wondering what type of indirect water heaters you all favor. What about designs, tank in a tank, or coil HX?
Gordy0 -
Tank in tank
have provided the best performance and least amount of failures. They handle hard water conditions much better than a finned coil type HX, from my experience.
Next would be a large diameter coil type HX, like the Viessmann, Buderus, and I believe Bradford White has a new line of large diameter, un-finned glass lined tanks.
Buderus and Viessmann have large cleanouts to check conditions from time to time.
hot rod
Thanks Hot Rod
Gordy0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
