Ultra
John L
John L Member Posts: 118
Thanks for the info.
John
  • John L
    Ultra
    I seem to remember a posting recently about a recall/issue with the ULtra, am I remembering correctly and if so what was the issue?
    I am quoting on a mod/con and ultra was one the HO liked.
    John L
  • Floyd
    Floyd Member Posts: 429
    Some Ultra's...
    slipped out of the plant mislabeled as LP instead of NG or the other way around....no biggie if you do your job and actually check combustion on startup.....if there is a CO problem you will find it then.
    You can install the Ultra with confidence that it is a great product. Your customer has made a great choice and has done their homework well.....
    Make sure that you install it exactly has WM has spelled out it their installation manual.
    There are many variations to the programming and some changes that really should be made to make it run even more eff. WM installs CYA programming from the factory..
    you can make it better if you take the time.... any questions, eml me....
    Floyd
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    My Pleasure
    n.m.
