LP Gas furnace venting
diesel24
diesel24 Member Posts: 2
I have an LP gas furnace. It has a single-wall vent that is run through a 2x4 interior wall. I discovered that it has been creating a tremendous amount of moisture inside the wall. The drywall on each side of the vent will have to be replaced. Any suggestions on how I can stop this moisture problem? Also, I was told that all LP gas furnaces must have a double-wall vent. Is this true?
