Steam Boiler Feed Pump
frank_25
Member Posts: 202
If ya really have a 100 gal condensate tank, I'd convert it to a boiler feed tank by installing a MM 157 as the pump controller/ primary LWCO, and maybe a probe type secondary LWCO. You will have to install a make-up water feeder into the BFT also.
MM 67
can a McDonald Miller 67 LWCO be adapted to a boiler feed pump control? Current system has a very large receiver ( close to 100 gallons, and a ½ hp pump. Need to control rate of boiler condensate feed. Currently, it has, I believe a 51-2, and the boiler is over feeding.
Jed0 -
LWCO
I do not have my books here but; I think the 67 is a LWCO with alarm contacts, and the 51-2 is a water feeder so it sounds like you do not have a pump controller. I think a bit more info is needed to help you.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
