3/4 Kitec feeding 2nd floor panelrads
Solarstar
Member Posts: 82
wall is apart and I need to feed the second floor for future panelrads. Will the 3/4 kitec carry about the 20K btus Max required for this. I think kitec pipe is a full 3/4 I.D. thanks Paul
3/4\" will ...
work but so will 5/8" (id that is)...1/2 would work if you had only 15k...kpc
1/2\"
will move 20,000 at a 20 degree delta t (2 gpm) 2.6 fps with 5.5 feet of head per 100 feet of tube.
5/8" would provide a little breathing room.
hot rod
this is relevant information for Sam...
just to run the idea by him...
bump.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 918 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
