need a gauge
Dave_12
Member Posts: 77
You might try two gauges -
(1) Pressure Gauge w/ an isolation ball valve
(1) Temperature Gauge in a separable well or
strap on Temp Gauge (not as accurate)
We sell Winters gauges which are pretty nice, but still have occasional problems with the T&P gauges. On the package boilers we sell the manufacturer supplied T&P gauges are probably the biggest warranty problem we have.
t/p
I have a plug on the elbow of a return manifold that is crying for a nice, accurate temp and pressure gauge.
Brand/model suggestions?
Thanks.0 -
Never found a good one yet! They never seem to last always out of wack or built up with condansation. I would sure like to know if the is a good one out there.0 -
I am trying to get one also but I haven't been able to find it. I was looking for PSI and Vaccum reading for my New Yorker Steam Boiler.0 -
still looking
Suggestions? Weiss? Would like to get a decent one on the first try. Thanks.0 -
gauges
I vote for separate immersed gauges. Maybe weiss thermometer and ? same for pressure gauge, 3.5" diameter maybe. Tim0 -
Wiess
I have used the Wiess for temp and I like, I get the LCD digital one works great
Do you have...
Picture, part numbers, availability?
I'd like better gauges.
Weiss
I second your nomination. Weiss does a good job with their gauges.0 -
Condensation
Try using a gauge extension with the loop built in. It traps moisture to keep it away from the gauge for longer life.
http://www.weissinstruments.com/catalogs/phc/guageacc.htm0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
