Dirt in steam lines
are "open" systems. That means they are subject to corrosion at all times...after many years the steel will create a lot of sediment in those pipes (especially the returns)...it can slow down steam and condensate thereby causing all kinds of other issues...if you are having issues...sounds like a place to look at...kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Dirt in steam lines
    Hi Everyone,
    Our building is supplied by Con Ed steam. I'm curious to know how dirt could accumulate in steam lines in a building due to the steam coming into the building. A contractor has recommended cleaning out the supply steam lines. Is this something that should be done on an annual basis? Thanks for you help. Thanks
