p/s piping question
Brad White_150
Member Posts: 29
mentioned in various literature. From a balancing valve standpoint, 5 to 7 diameters straight run upstream and 2 to 5 diameters downstream are standard minimums depending on the manufacturer. 7D seems to be the most common upstream recommendation in AABC and NEB balancing guidelines.
In short though, the more the better.
do you need
laminar flow before and after a pair of closely spaced tees?0 -
By laminar flow
you mean a lack of turbulence, yes.
It is a matter of degrees, but turbulence is itself a pressure drop, sort of like sibling rivalry in the backseat in a long car ride.
If the turbulence creates enough pressure drop in the main, it could force/induce flow into the secondary circuit. How much depends on the degree.0 -
a rule of thumb would
be, say 4 pipe diameters of straight, reamed pipe from a 90 degree elbow to the first tee, or greater?0
- 87.4K THE MAIN WALL
- 15.8K Strictly Steam
