water temp
Bob Sweet
Member Posts: 540
house? How is your system piped? Is this a cold start boiler?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=443&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
water temp
We have a two part system one side has a constant cic with plate steel radiators with deverter valves,the other side of house has fin tube basebord with room temp controling cir.the system has ar-6 control set up as tankless ,my problem is when t-stat is not calling on one side, water temp drops on the side with constant cir becuse there is no call for heat what do you do0 -
water temp
two pipe system, set up for tankless coil zc and zr are jump0
- 87.5K THE MAIN WALL
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
