Crown Boiler Condensing unit
Uni R_2
Member Posts: 589
How low will the 90MBH unit modulate?
Condensing Boiler from Crown
In answer to the calls we have been receiving about our new line of condensing boilers. Attached are some pictures of the new Bimini - BWC120 (120MBH input)condensing boiler from Crown Boiler. It comes ready to be mounted on the wall but there is also an optional floor pedestal for sitting the boiler on the floor. As you can see we are using a concentric vent, the basic vent kit is included with the boiler as is all wall mounting hardware. A 90MBH input unit will be available in early 2007.0 -
BWC090
The smaller boiler will modulate down to 30MBH, The larger modulates down to 40MBH.0 -
Installer?
Hi Lee. I'm guessing you work for Crown. I just moved into a house in Philly with a 4-year-old Crown boiler, and I'm wondering who installed it for the previous owner. Whoever did it also replaced all the pipes in the basement below ground level, and seems to have done a fine job. Since Crown seems to be located in Philly, any idea where I could start trying to find out what local companies use Crown? I have a 100-year-old 2-pipe steam system.
thanks!0
- 167 Indoor-Air Quality
