Burnerjet.inc
Mark Wolff_2
Member Posts: 76
http://www.oiltechtalk.com/Just%20For%20Tek's/abc-sr.htm
I hope it helps.
I hope it helps.
burnerjet inc. Parts
I have a sun ray burner on my natco boiler at our concrete plant in need parts for my burner. The fule pump is locked up. Any one know how to get to them?0 -
The fuel unit...
Should be "generic."
On the fuel pump, a brand (Sunstrand, Webster, Tuthill, etc.) should be noted. Near that label or engraved/stamped number, alpha-numeric model data should exist.
That "alpha-numeric" data explains the entire pumps characteristics, and allows you to buy a replacement or cross-refer to an exact replacement.
However, it is extremely abnormal for a fuel pump/unit to seize from wear or a pump breakage. Almost always, the problem is from water contaminated fuel.
With all this rain we've had...
Check the tank and tank to burner piping and filters. No sense putting a new fuel unit in witout eliminating the cause of failure, right?
- 167 Indoor-Air Quality
