More CO
Brad White_9
Member Posts: 2,440
more BS.
I am off to sleep, but before I go.
Read <a href+http://www.woodtv.com/Global/story.asp?S=5688961&nav=menu44_2>this.</a>
1 to 70 ppm is "normal".
Just so you know. That is not true. And even if were, the alarms these "experts" recommend would not respond to those levels. 70ppm??? 4 hours before the alarm has to sound. Look for the UL label.
Night all.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Night all.
Mark H
Normal?????
Must be the same article I just read: "The Consumer Product Safety Commission reports the normal level of carbon monoxide is between 1 and 70 ppm."
Hard to believe.....
http://www.woodtv.com/Global/story.asp?S=5688961&nav=menu44_100 -
Normal?????
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
