Another glycol question
hr
hr Member Posts: 6,106
a need for an anode in a closed loop, barrier tube system. Although the manufactures may prefer they stay in for warranty.
Glycol may go after the anode depending on the material. You really don't want to spring for Al glycol $$$ just for the anode rod.
I'm not sure about a magnesium anode and glycol?
I know steel or cast boilers don't use anode rods :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Tombig_5
    Tombig_5 Member Posts: 60
    Remove Anode?
    I have to temp heat a slab during construction. I'm installing an LP HW heater as nat gas service is months away. I'm running glycol for obvious reasons. Should I remove the anode rod? For that matter, should the anode be removed in permanently installed H2o systems using a water heater?
  • Tombig_5
    Reuse Glycol
    Since the 60 gals of mixed is going to be used for 3 months or so I was thinking of removing it and using it with a HX sidewalk/patio snowmelt coming up. If the (I assume) magnesium anode reacts, I don't want to install an inferior mix to a new system down the road. I will be using Cryotec 100 which is not aluminum compatable.
    hot_rod Member Posts: 26,619
    keep glycol sealed
    to help protect the o2 inhibitors. I think moving it around too much would lessen the protection. And always check the ph to keep it healthy and happy.
    hot rod
  • Drew_2
    Drew_2 Member Posts: 158
    Magnesium
    I've attached a chart for pH and magnesium corrosion. You make the call.
