How good are Crown Tobago HW boilers?
Ray M
Member Posts: 94
I to have install 6-8 of the tabagos, like ken said a little noisey. The Freeport CT line is my choice.
Ray M
Ray M
How good are your experiences w/ Crown Tobago HW boilers?
I put one in and was impressed. I liked the fact it has CI push nipples, and it is competively priced. I just came from a Weil Mclean that was leaking from the seals to the extent that it rusted through the threaded rod, the rear section separated a little and the seal apparently burned up, as a new rod can not stop the leaking. Am inclined to replace this loser with a Crown, as the piping and top flue configuration is similar.0 -
Got half a dozen in this year. No problems whatsoever. A bit noisy at the max firing rate. Didn't need it anyway, just tried it to see how it performed. Nothing like experimentation! At the bottom rate it is very guite.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
