Manifold mounted below PEX staple up
MikeL_2
Member Posts: 538
I am installing a PEX staple up job. It is a very, very open floorplan. I can't find a good location on this main floor to mount the manifold. Would it be OK to mount the manifold below the pex? Would this cause air purge problems? Should I tee off the manifold and raise an air vent above the height of the PEX?
Thanks,
Dan S.
Thanks,
Dan S.
Purging should not be an issue
with smaller tubing especially. I have a radiant second floor bathroom with my manifold in the basement. 114 feet of tubing, no air. Just purge each tube one at at time using full pressure water.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
