relief valve
ALH_4
Member Posts: 1,790
That looks like something out of <a href="http://fwp.mt.gov/lands/site_281895.aspx"target="_blank">Lewis and Clark Caverns</a>.
-Andrew
-Andrew
relief valve
Anyone looking for a slightly used relief valve ?
I will give you a good deal........
Dave in NH0 -
Dave
I will start the bidding at,...........$150.00, but you must cover the shipping....:-)
Mike T.0 -
almost new
they aren't bad until they look like this.0 -
Nothing that a wire brush and a little paint couldn't fix;)0 -
Larry-
There is a story behind that valve. Anything to share?0 -
Brad
This was sitting on the "shelf of shame" over in the boiler code area of my building (dept of labor and industry) and was just one of several things that you don't want to see while looking at a boiler. It was scooped up by one of the boiler/high pressure piping inspectors at some time in the past and I never did get a definitive answer as to the cause of its demise. I first posted this about a year ago and there was a bit of speculation by those here. All I can say is that at some point the pressure was relieved!
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
