direct hwt
terry_5
terry_5 Member Posts: 92
triangle is 33% more,but any better?Connecting to Knight boiler!
  • Uni R_2
    Uni R_2 Member Posts: 589
    SS vs Glass
    With the stainless steel Triangle Tube tank, you shouldn't need to be checking the anode rods. Most would say that it's a better choice.
    How chlorinated is your water?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    make sure water is tested
    I have had issues with stainless steel back in the days when I would ask the home owners if they had hard water, funny they always would say "no" or " a little". Then a year later I would be back removing the tank and putting in a new one. Then test the water to find in was 3 to 4 times beyond hard. Once a water softener was installed never a problem. I am partial to the Buderus tanks with the big anode rods and clean out hatches mmyself though.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
