How to get a new Water Control Part - HELP
Robert O'Brien
Member Posts: 3,584
a low water cutoff. Call somebody locally to replace or repair
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Water Control
Hi - Our heat wouldn't go on earlier, even though the water level was fine, and we were told we would need a new Boiler Water Level Control - we're told it's not easy to find, so I attached two photos of it - one of the part and one of its label - any advice where to get one and what it should cost? Thanks all for your constant help and guidance - Todd0 -
McDonnell Miller #67
But like posted above, this is not a home owner do it your self project. You should have your heating equipment checked EVERY year.
Mike T.0 -
Any idea how easy to get or what this should cost?
Hi there - I was told this part may not be easy to get - any good sources for them and any idea what it should cost me? (I will DEFINITELY not think of doing it myself - I'll have a licensed person do the install!) Thanks - Todd0 -
LWCO
Copy and paste this. From Watts website
http://www.watts.com/scripts/pro-products.watts?_cfg=./db/pro-products.cfg&_fil=cat2='Low_Water_Cut_Offs'.and.cat1='Hydronics_and_Steam_Heating'.and.div='_watersafety-flowcontrol'&_sn=pro-products&_tar=_view5_watersafety-flowcontrolThere was an error rendering this rich post.
hvac
Any good local hvac company can get that and put it on for you. As prices vary greatly in different areas that's your best bet
Lucky
Consider yourself lucky that it failed in the OFF position. That particular item should be flushed regularly, and checked for operability on a regular basis as well. When that DOESN'T occur, the failure that follows is usually a boiler. As stated above, it is not a "homeowner" project, nor do you want to take any chances-it will be a few hundred dollar solution to a several thousand dollar problem.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
