Building Radiator Covers
Paul Fredricks_3
Member Posts: 1,556
You could even use an emergency blanket, available at your local camping supply, sports authority, wherever. They are thin, cheap and fairly tough.
What to use for the back?
A quick question for anyone here that may have made their own radiator covers - I copied the design of a couple that came with my house, and basically built a wooden frame for the front (with a decorative aluminum screen and a couple inches of clearance across the bottom), with a top and two sides.
That took care of the cosmetic issues, but for evenly distributing heat, these covers should probably have a reflective back on them. What have you used for this? The existing ones have foil insulation (foil-backed craft paper) stapled to the back, but this is not easy to find at the local Home Depot. And the places I've found online only seem to sell it in 500 sq ft rolls (I need maybe 1/50th of that). Does anyone have any other ideas? What has worked for you in the past?
Thanks for your help...0 -
what about heavy duty aluminum foil at your local supermarket0 -
1/2 rigid foam boards
Home depot/ Lowes should have these. The have a reflective foil face on one side..0 -
You want to put the aluminum screen
across the top also. Otherwise you can reduce the radiator's output by up to 33%, with commensurately higher fuel consumption.
Radiator covers belong to an era when fuel was cheap. We'll never see that again.
Watch too much TV
Ask This Old House did a show on how to... check thier archives0 -
Radiator cover
I made one in my home out of 1/2" birch plywood and 1/2" tuff r foil faced insulation with an open top and 30% open in the bottom front as per Dans description in EDR. Dan says it increases the radiators capacity by 10%. I liked it better without a cover, but I had to cover it for the safety of my children. I added some dentil crown to it with columns, I stained it to match the furniture, I covered the opening with an expanded metal sheet with large holes so that it's open to air, and I installed a Danfoss TRV on it.
I don't have a digital camera to upload it here, but it looks and works great.
