How often should I clean/drain steamer?
Charles G.
Charles G. Member Posts: 113
What does the owner's manual say? You should have been given the instructions when you gave them the check...
But if not, go to http://www.weil-mclain.com/literature/literature.htm
  • Howard_4
    Howard_4 Member Posts: 15
    How often should i clean/drain the boiler? I have a new WM EG 40
    It has an electronic low water cutoff. I just want to be safe, i dont want to keeping adding fresh water to prevent corrosion. Also how much should I drain?
    Last winter the boiler used about an inch of water per month in the site glass.
  • Howard_4
    I will look, but is there any common ground on this topic in general with steam boilers?
