Refracto-what?
Techman
Member Posts: 2,143
Morning
professor!Mineral,AlekBenzene,P.O.E.comes in 4-5 different grades,P.V.E.Sometime back oil interdilution was required to be within certain percentages min-A.B.,50%-50%;min-poe ,5%-95% and so on .Whats a guy and his refractometer supposed to do these days? Removing the refrigerant,then the welded comp and then the oil , then adding the new oil,comp,refrigerant then running the system,then rechecking the oil-oil%,that gets very costly .Even with a 5-H.P.Copelametic its costly .Do I dust off my oil checker tool? Thanks!
Get a sucker
You need an oil pump kit that can suck out the oil thru the suction line. They make a kit or you can make one if you have an oil pump. I use a Yellow Jacket brand. Took oil out of a 3/4 hp semi-hermetic.
What kind of system are you working on, refrigeration or a/c?
Don in Mo0 -
Oil sample
Morning Don in MO.!I am talking more about refrig work because of the oil's involved. On semi's I have no problem changing the oil thru the crankcase fitting . I will check out the pump you are talking about. Can all or most of the old oil be removed from the hermetic crankcase thru the suction line this way ?Hay, how did I get up here?0
- 125 Chimneys & Flues
- 19 Recall Announcements
