honetwell 3 way zone valve
clammy
Member Posts: 3,242
wondering if some one has a model for a 3/4 ips or sweat 24 volt n/c zone valve having a hard time getting a model # it seems not many are using them and i'm getting that look from the counter guys .You know only guy who,s even ever asked for one .thanks clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
3 Way Valve
I get them from Johnstone supply. I will look for the model number.
Ray M0 -
zone valves
zone valves
And the magic model number is 8044E1011 !!!
Hope this helps
Ray M0 -
Thanks Ray
Thanks man i need to use one for a re circ loop to pervent freezing on a existing loop which is ran in a out side wall .I'll be using it in conjuntion with a mech outdoor sensor and a freeze stat located in a a hydro air unit to pervent possible freezing of lines and coil and to elimanate the constance thermal migration which happens every time another zone calls .I did not set up the original piping just correcting it to elimate and ensure that it's not a issure at a later time thanks peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
I use them for micro zone's off of existing zones.
Thanks Ray M0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
