enter at your own risk
The one who used to live here had recently drowned. But there has been a new birth...Welcome to the pit wetheads...
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    I
    Knew there would be a Viessmann at the bottom of those stairs! Another excellent Viessmann install,you do some beautiful work.
  • Ray Landry
    Ray Landry Member Posts: 203
    When it comes to flawless installs you are unmatched! I really like your idea of using a veiga manifold and telestats with pex wips rather than copper. Eliminates the need for a purge set up as well! Curious, do you reley on the hy vents on the saftey header and on the veiga manifold for air elimination or do you add a spirovent? Also, is it a huge time saver using the manifold versus hard piping with sweat in zone valves? looks like it is!
  • Uni R_2
    Uni R_2 Member Posts: 589
    Twisted power!
    I'd straighten that box out, but nice clean work!
  • American plumber
    American plumber Member Posts: 89
    vitorond 150
    Thankyou for your kind words but "flawless" might be pushing it a bit. I like the manifolds also,they are expensive but quick and easy to install.Veiga is now using chinese components which I always find a little scary.The "safety header" is actually just a 1-1/2" Taco air scoop with a 3/4" ball valve on top.Even without the long straight run to the inlet of the scoop it works really well.I find with most setups like this purging is not necessary.Have you noticed Tacos' scoops are made in India? I always wonder what those Indian foundries look like.
