Taco 00VS
Cosmo_3
Cosmo_3 Member Posts: 845
This might be the ticket for cast iron boiler protection. Just pipe pri-sec, set the boiler loop for minimum 135 degrees.
I will have to check on price, thanks
Cosmo
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    I finally
    got it installed. In my own house, I took out the existing atmospheric gas furnace, and installed a high efficiency heat pump with a back up hot water coil which is powered by a Munchkin. The Munchkin also heats my Snow melt and radiant floor, and eventually an indirect for domestic hot water. On the "back up" hot water coil loop, I have installed a new Taco 00VS, variable speed circulator. I have programmed it to maintain 115 F supply duct temperature sensed by a thermister is my supply plenum. When it gets cold enough outside, that the heat pump cannot heat the house alone the circulator will sense the lower supply duct temperatures and will circulate enough hot water to maintain my warm air. The colder it gets outside the more hot water it will need to circulate. I've just been playing with it turning the heat on and varying the boiler temperature so it will have to ramp up and down. What fun! My dear and patient wife came down and remarked how hot it was getting upstairs, (:X) so I had to stop. :( Seems to work very well. I plan to use another one on a Solar job I just got a deposit on. WW
  • Wayco Wayne_2
    It can be used for
    Variable speed injection too. There are several ways to use it. WW
  • Mark Chaffee
    Mark Chaffee Member Posts: 30
    00-VS for Boiler Protection
    You can also use the Taco 00-VS for boiler protection. Install the pump in a by-pass line, dial in the boiler minimum temperature then put the pump into direct acting mode. EASY. Check out the attachment for all the details.
    - Mark Chaffee
    Taco, Inc.
