What is it?
Robert_15
Member Posts: 62
cotton candy maker?
Any guesses?0 -
four barrel holly w/ super charger0 -
it looks like it was from a washing machine made to water the lawn like you see with the plant water jugs :-) just hook a hose to the front ;-)
just make sure you turn the barrel around so the hose is in back so you don't get wet when you push it and you'll be all set. :-)0 -
Potash spreadder outter *~/:)
you walk along and chemical fertilized is blown all over your shoes,socks and pant legs and all around you is a big white cloud like the little "Pig Pen" charater in charlie brown.
Just as you Revealed the answer i envisioned a portable propane heater that one cranks up , gets a little warm , whips out the portable CO detector goes' ok. Its a little high'
then move to another area0 -
None are even close...
...it's actually related to heating...0 -
Viessmanns prototype of the inox radial burner? :-)
Cheryl thinks:
it's an incredibly poorly designed tubing uncoiler. LOL.
Must take forever to load those coils into the drum!
Wallace Radiant Design
Espresso Machine??
Biggerstaffradiantsolutions.com
Got it !
It's a portable "redneck" Chiminea. Chris0 -
What is it?
I know exactly what it is.... It's portable corn-burner for a mobile home. Even has a door for ash removal..0 -
Even if it isnt you sure made a good point0 -
You got it!
A portable radiant campfire!!!
Used by members of the camping/travel club I work for. They insist it works very well and looks quite nice with the glow through the holes of the washer tub. Note the cleanout door!0 -
i really was going to say campfire but then thought why would you need the doors when you can load from the top
thanks mike0 -
They told me to remove the ashes.0 -
dryer
I was thinking redneck clothes dryer- "Here ya go, boy. Go run this around the park a few times"0 -
Portable ash tray
Just think how long it would take to fill it
I thaught i saw one outside a trailer in the hills one day!
terry0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
