wireless thermostats
BillW@honeywell
Member Posts: 1,099
The T8665A1002 wireless. It's battery powered and based on the Chronotherm 4 thermostat. It requires the W8665A or E equipment module which mounts in the mechanical room and is hardwired to the equipment. The stat has a 200' range. Available only from your local heating & cooling contractor. Go to www.customer.honeywell.com for more info.
Any good or bad experience with wireless thermostats? Any interference from other electronics?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
