Which boiler is better for my building?
Jamie_6
Member Posts: 710
I would not worry so much about the difference in product as I would about the install, especially with steam! A lot of the time different types of boilers are just based upon preference. I do agree with the other guys about the wet based boiler and power burner. If need be you could always but an oil burner on the front of that monster.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I live in a 6 unit condo building with steam heat. We need to replace the boiler and were given two options by the contractor: Weil Mclean #LGB.8S- 9100 BTU, or Smith #G19-8S- 9000 BTU. The contractor says the Smith boiler is 10% more efficient but will cost $1,500 more. Is it worth the extra money?
Thank you,
Ellen0 -
The Smith...
is a better boiler. The design is wet base,power burner vs. the std. gas atmosheric... in effect the Smith is a oil boiler w/ the gass burner on it. As w/ any boiler install it has to be installed properly. How many installs has this contractor done? References? just my thoughts...kpc
Like Kevin I would prefer the Smith wet base boiler power burner can use oil if that needs to be an option and how long will it take to earn back that $2500 in saved fuel.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
