A/C Question
Mike
Member Posts: 94
you'll also need to install a hot gas by-pass, for capacaty control. have yet to see unloaders on a tin can.
hi i was wondering
i know with a mini split system you can have 4 indoor units with one compressor.
but is it possible to have 2 air handlers and (a-coils) share the same compressor if both zones are on the same
t-stat so they would both come on at the same time
of course the compressor would be sized for the whole load
like a 4 ton compressor would serve 2 (2ton) air handlers
right now i have (1) 2ton unit but i will be adding a bedroom bathroom addition that needs 1ton would it be cheaper to run a new 1.5ton 14 seer with a new air handler. or would it be cheaper to run a 12000btu through the wall sleeve unit
i know the though the wall unit would be cheaper then new duct and air handler but i'm looking at whats the best operating cost
thank you
Jason0 -
Jason.......
Why don't you post your question at the bottom under AC & Refrig?0 -
i did not see that i don't go that far down the board :-)
thanks
Jason0 -
This content has been removed.
TXV control coils
I have done it and it will work.
I would use liquid stop solinoid valves and TXV evaporator to handle varying loads.
I have also seen 4 compressors in one condenser they were made in Rome NY
Good luck
terry0 -
Thanks Mike
I forgot that part when i suggested TXV good you added what i missed
Terry
Jason
How about a ductless split ?
Simple, efficient, quiet.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
