steam system air lock on return
Stan_6
Member Posts: 1
I have a steam boiler that I have been having a problem with one area of the house. The steam only travels half way down that branch and stops. I found that the return line from that branch is very hot. The pitch of the supply and return are correct. I have changed the steam vents and the main on that branch. I have found out that when I drain the return line the steam will travel all the way through that branch of that area. Please help.
drain water from the return? can you snap a picture? where you vent is at this branch.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
