One-pipe steam -- loud rumbling noise after burner shuts off
Mark Cioffi
Member Posts: 1
Hello -
We have a one-pipe steam boiler that is two years old (replaced an old one) that has recently been making a very loud rumbling noise a few seconds after it shuts off upon satisfing the thermostat temperature level. The noise is audible throughout the house and sounds much like an 18-wheeler downshifting in the system. It lasts 5 to 10 seconds, and of course, happens only sporatically -- but mostly in the wee hours of the morning. Technicians have come out twice but were unable to duplicate the noise and haven't offered any definitive reasons or solutions. They seem to feel the system is safe, but we want to be sure.
Do folks here have any ideas? I'm sure that I've left details out that may help solve the mystery, so please ask away if you have ideas. Thank you much.
Mark
Mark
It sounds like it might be collecting condensation somewhere in the system and the steam pressure is holding it there until shutdown. Most likely near the boiler and header. Then the condensation water is dumped back into the boiler all at once on shutdown. I had this once on short-cycle. Try this. Time the length of normal burn. Then, shutdown the system for a couple of hours until the mains get good and cold so when you fire it back up it makes lots of condensation. When you fire it backup run it only for the normal burn time that you timed. Listen for the noise. If it rumbles thats probably what going on.0 -
Fuel?
What fuel are you using. Oil burners will do this. If it is a good tech can figure it out.
All the best
Robert
ME0 -
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
