Help-need coil for Olympia boiler
Saggs
Member Posts: 174
thanks for the input I'll make some calls and see what I can find. I knew someone would have a suggestion on the Wall.
Help!need coil for Olympia boiler
Got a guy who needs a new coil for his Olympia OL-100 oil boiler. I've tried all the local wholesalers and their reps. The plate is vertical at 6" by 14" w/ 10 bolts and 3/4" tapping for the aquastat. Any suggestions? Other than getting a new boiler? Thanks0 -
Did you try....
tfi-everhot? They have a lot....If not I think that is an Axeman-anderson boiler call them...(570) 326-9114...kpc
yes
That would be an Axemann.0 -
If TFI/Everhot doesn't pan out, try Heat Transfer Products.
Our friends at HTP make or made coils and covers for almost everyone. Chris0
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
