Metric to Imperial connection
Ron Schroeder
Member Posts: 995
McMaster.com has a lot of steel British and metric to NPT adapters. Uou might be able to make up what you need with two adapters. Also try hydrolic hose and fitting suppliers. They usually carry a lot of european adapters.
Metric to Imperial pipe fittings
Hello,
We are in the HVAC business where we are to receive some products from Europe (Italy) that we will need to hook up to our piping in the US. Is there a manufacturer in the USA that sells/manufactures wroth copper flush bushings that will adapt from the metric dimension pipe to the US copper water pipe?
Thank you in advance0 -
Ya might look at \"Swedgelock\" fittings!
Elizabeth,I have been waiting for...
some freeze proof valves in 1&1/4 ,1 &1/2, 2"from Italy ,They are of a particular interest to me. while you are there , would you chirp up casting the plastic valve in standard American sizes and threads??
Thanks. I Knew i could count on you. *~/:)0 -
BSP
Hi Elizabeth,
If the connections are threaded you may well find they are BSP threads, over 50% of the brassware manufactured in Italy comes into the UK. I would have said 'exported' but with both countries being part of the EU, that term may not have been correct.
We order Plumbing items from Luca in Italy and have them here in Scotland in five days.
I hope that's some help.
Regards.
Jimmy0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 982 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
